-   Wheels, Tires, Brakes, and Suspension (https://www.acura-legend.com/vbulletin/forumdisplay.php?f=94)
-   -   I have found our G2 bbk solution (https://www.acura-legend.com/vbulletin/showthread.php?t=147099)
L3GDKANG/JDMKANG 10-04-11 07:24 AM
Ok now for the mini bbk you will need 99-04 rl brackets and rotors and since they work now all you need to do is buy a bbk kit for the rl ka9! I've been doing my home work and will get pics and progress!
BIGBOY 10-04-11 10:42 AM
What about that other source we were talking about?
L3GDKANG/JDMKANG 10-04-11 11:05 AM
Yep those will work as well
L3GDKANG/JDMKANG 10-04-11 06:16 PM
L3GDKANG/JDMKANG 10-04-11 08:44 PM
No that's not my legend nor my setup just yet. But any rl ka9 braket and rotors will work! So any bbk for a rl will be a direct bolt on.
L3GDKANG/JDMKANG 12-06-11 08:15 PM
make that 99-04 rl's for the mini bbk kit
L3GDKANG/JDMKANG 04-15-12 08:53 PM
NYTAHOE 04-16-12 03:51 PM
Is the solution for both axles? Do you use Legend or RL pads? Did you brush or spray your calipers?
L3GDKANG/JDMKANG 04-16-12 05:32 PM
these are just for the fronts only. all rear bbk's have to be custom made so far. i used a spray gun on these and car paint and cleared them. you can use either pads but the t2 pads cover more of the rotor then the others. so im going with t2 or after market tupe pad.
L3GDKANG/JDMKANG 04-21-12 05:26 PM
ok heres the t2 and rl compair. top is t2 the space between the area where the rotor go is mch winder then the t2.
http://i624.photobucket.com/albums/t...f/b5d4dacf.jpg
Qs91Coupe 04-21-12 05:46 PM
I'll be looking for RL brackets tomorrow.
L3GDKANG/JDMKANG 04-21-12 05:50 PM
make sure they are 99-04 rl brackets on it!
pokal 01-04-13 05:37 AM
and why 99-04 rl brackets? ?
L3GDKANG/JDMKANG 02-03-13 05:44 PM
so you can run bigger rotors
misterOG704 02-04-13 02:44 AM
Just wondering, is a master cylinder upgrade needed? or is the Legend stock one good enough for the RL calipers?
