My car feels like a boat at highway speeds - suspension help needed... - The Acura Legend & Acura RL Forum
Old 10-26-07, 10:21 PM   #1 (permalink)
AllCammedUp's Avatar
Car 1: 1991 LS Sedan
iTrader Score: 4 reviews
Everyone,
My car feels a bit 'loose' and 'floaty' at highway speeds and I'm wondering what I need to look into to correct that. I've recently put some new old-stock 15" OEM wheels and tires and although the car rides smooth, it just feels 'sloppy'.
Any input is greatly appreciated.
BTW, the car has 136K on it, and from what I can tell it still has the stock struts/springs and everything else suspension-related appears to be stock, so I'm sure nothing has been replaced over the years (I'm the most current owner, not the original owner of the car), and I don't have the service records, so I don't know that some of the suspension hasn't been replaced at some point... it just doesn't feel like it, LOL.
Thanks,
Whitney
AllCammedUp is offline   Reply With Quote
Old 10-26-07, 10:46 PM   #2 (permalink)
Car 1: 1992
If it feels like it, then most likely the OEM shocks are dead. I know mine are You get the spongy, unstable feeling on bumps and turns. If you want to reduce the boat feel, then get new shocks. While upgrading shocks wont make your car feel like a BMW M5, it's going to be better than blown shocks anyday.
1992 Acura Legend LS sedan
GSteg is offline   Reply With Quote
Old 10-26-07, 10:50 PM   #3 (permalink)
Blackend Motorsports
3 Wheel Slot Machine Champion
Blackend's Avatar
Car 1: Blackend Motorsports
Car 2: 1995 LS Coupe
iTrader Score: 23 reviews
Ksports will help that!
Blackend is offline   Reply With Quote
Old 10-26-07, 10:56 PM   #4 (permalink)
Yep, that's a good synopsis, so I'll look into some new struts/shocks.
Blackened, are the KSports 'racer' components? I just want something that is a good solid upgrade from the stock components... not something that is adjustable, etc. and that will require me to 'tweak' on them. I just want to install replacements for OEM and get the problem resolved and an upgrade at the same time.
Thanks,
Whitney
Old 10-27-07, 12:02 AM   #5 (permalink)
Blackend's Avatar
Yeah - Ksports are coilovers. I would look for an MLS strut brace, that does a TON for the handling of the Legend by itself. If that's still not enough for you, I would look to swap in some Koni Red shocks with the OEM springs, and then if that's still not enough, look for some Eibach springs (which will also lower you a bit.) After that, the mod-bug should be in full effect and you can pick up some sways, the rear tie bars, and then upgrade to Ksports...kinda my lifetime of suspension mods so far
Old 10-27-07, 12:35 AM   #6 (permalink)
BobbyGlide's Avatar
Car 1: 1991 Acura Legend L Coupe
Car 2: 2011 Camry SE V6
Send a message via AIM to BobbyGlide
Everyone,
I have Konis and Eibach, full stiff and lowest perch and my car feels 'loose' and 'bouncy/wavy'. Is this normal with this type of suspension setup?
Rob
BobbyGlide is offline   Reply With Quote
Old 10-27-07, 02:37 AM   #7 (permalink)
Blackend's Avatar
Rob
Imagine the way your suspension is setup - the OEM equipment was set to make the Legend handle like a sport/luxury vehicle, and you've stiffened up the shocks/springs now. Well, all that weight that made the ride so nice on OEM suspension is now upsetting the chassis because only one part of it (the 4 corners independently) is stiffer. You really need to tie those corners together by way of a strut bar and sway up front, and at least a sway in the rear if not some tie bars as well (or God forbid we ever get the rear strut bar designed, one of those too!)
Seriously though, I cannot speak highly enough of Fut's MLS strut brace as to how well it evens out our suspension and handling. It really is still my favorite mod for this car.
Old 10-27-07, 10:02 AM   #8 (permalink)
BobbyGlide's Avatar
I have the MLS copy bar and an Addco rear sway bar installed as well and the car feels bouncy and unstable. I have Futs tie bars and a Addco frontsway bar that I havent yet installed. Maybe when there installed, the suspension feel will get better.
Old 10-27-07, 10:52 AM   #9 (permalink)
I've got one of Fut's MLS Copy Bars in the garage waiting to go on... I just didnt' know if there would be improvement if the shocks were shot, so I've not installed it yet.
I'm hoping that with the engine dampner, the copy bar and new shocks/springs I'll be set up good for a bit.
Thanks,
Whitney
Old 10-27-07, 03:19 PM   #10 (permalink)
Fut
Car 1: Blk/Blk '94 GS 6 Speed [+] '90 LS 5 Speed Sedan
iTrader Score: 33 reviews
Send a message via AIM to Fut
I've got one of Fut's MLS Copy Bars in the garage waiting to go on... I've not installed it yet.
Dude you gotta get that puppy installed, the sooner the better.
One...
Fut
G1 Lowering Control Arms Group Buy
6 Confirmed Buyers - 4 Additional Buyers Needed
Fut is offline   Reply With Quote
Old 10-27-07, 07:11 PM   #11 (permalink)
One...
Fut
10-4 man. Will do! I just didn't know if it was worth it if the struts were kaput.
Thanks,
Whitney
Old 10-27-07, 07:27 PM   #12 (permalink)
Fut
Install it now then post results so we'll all know. Do the same after instaling new struts. That's the best way to judge.
One...
Fut
Old 11-02-07, 01:11 AM   #13 (permalink)
I will install the copy bar this weekend to see what the difference is.
Does my description sound like my original problem will be remedied by new struts and springs? The car just feels 'sloppy' when going over bumps and breaks in the pavement... almost to the point where it seems to 'slide sideways' (if that makes sense) if it gets unsettled enough.
It's a pretty alarming feeling to go over a bump or a joist in the concrete and feel like your car is hydroplaning (slightly) off to one side. This only happens for a split second until the car has grip again, then all is well.
I just hope that this is the fix for the problem I'm describing. Thanks again.
Thanks,
Whitney
Old 11-02-07, 01:53 AM   #14 (permalink)
Blackend's Avatar
I would be willing to put money on the fact that after the MLS is on, that feeling goes away.
Old 11-02-07, 11:57 PM   #15 (permalink)
Hmm. Hopefully so!
Thanks,
Whitney
needed socal suspension shops or good mechanics socal needed toyotas4life86 Wheels, Tires, Brakes, and Suspension 5 08-01-06 05:12 PM
Gas Efficiency at Highway speeds. Engine Condition mischief4l Second Generation Legend (1991-1995) 5 12-01-04 01:37 PM
Braking at highway speeds is whack thecandybar First Generation Legend (1986-1990) 2 01-13-04 07:51 PM
Suspension advice needed - Urgent johneder Engine & Performance Modifications 0 03-30-03 07:10 AM
Str8 Hater on 6-speeds and 5-speeds CakeDaddy The Lounge 10 06-22-02 05:47 AM
