question - The Acura Legend & Acura RL Forum
Old 07-25-06, 04:44 AM   #1 (permalink)
question
i plan on getting some 17's or 18's on my sedan. im not sure what offset would be the best on 18's. i know the best i think for 17's are 40mm? what would be the best offset for 18's and what would the best tire size be for 18's?
90bluelegend is offline   Reply With Quote
Old 07-25-06, 07:05 AM   #2 (permalink)
If no one is able to answer your question (I sure as hell can't), I would suggest checking out tirerack.com They have alot of info on stock or custom wheel and tire combinations.
*bughouse* is offline   Reply With Quote
Old 07-25-06, 12:33 PM   #3 (permalink)
More than one person here has fitted 17" wheels with 45 mm offset. I have some 17x7 42mm on order and will report fit in a week or so. Stock is suppose to 45 mm.
Discount Tire actually has more variety of wheels for the G1 Legend but TireRack has that nice Java thing to look at selected wheels on your car...too bad they don't have a G1 Legend. I used a G2 with appropriate color to get a pretty good idea.
Also look at Motegi, Tenzo, DAZZ, Sparco, ad infinitum.
slartibartfast is offline   Reply With Quote
Old 07-25-06, 03:18 PM   #4 (permalink)
Additional information to better manage your decision making:
Front wheel drive cars such as the Legend employ a more positive offset. This just means that the lug holes are located more to the outside of the wheel to provide better vehicle balance, so to speak.
Rear wheel drive use a more neutral or negative offset. Envision that BMW rim and you'll see why they look so elegantly angular as opposed to the flat rims that we have.
+40 ~ 47 are the reasonable ranges. Too much makes them look too 'in', risking fender rubbing, and not enough makes the car look like a lifted-up truck.
gwinbeer is offline   Reply With Quote
Old 07-25-06, 03:23 PM   #5 (permalink)
i think im gonna get some 17x7's with a 40 offset with some 215/45/17's tires.
Old 07-25-06, 06:10 PM   #6 (permalink)
check out my setup..not so sure what my offset is but it's 17 x 7
craulto is offline   Reply With Quote
Anybody Notice Their Post Counts Change When They are Not Posting... 91LSMAN The Lounge 52 02-07-06 12:36 PM
Nitrous Prep question and Zex switch question Plopper Engine & Performance Modifications 16 03-20-05 02:54 PM
All NOPI 2004 Threads in here! sleeprlegendcp Meets 26 09-16-04 03:30 PM
Question about the search feature... Green Plague First Generation Legend (1986-1990) 3 03-13-04 01:34 AM
The Million Dollar Question???? ttvr4 Second Generation Legend (1991-1995) 5 07-07-03 10:09 PM
