-   Wheels, Tires, Brakes, and Suspension (https://www.acura-legend.com/vbulletin/forumdisplay.php?f=94)
-   -   Tire and offset recommended for steelies? (https://www.acura-legend.com/vbulletin/showthread.php?t=149233)
WickedShepard 03-06-13 08:16 AM
I'm considering in purchasing wide steelies my 92 sedan because I am interested in the wide and low look, I'm wondering if anyone has tried spacers and what tire height and offset would fit on a legend if it is lowered an inch or 2 without flaring the fenders
L3GDKANG/JDMKANG 03-07-13 10:26 AM
what you will need is the size rim you wanna use as that will play a big factor. if you wanna drop the car with a tucked look for 6-7" rims anything wider will need fender work.
WickedShepard 03-07-13 03:56 PM
The rims will be 15x8 I want a wider stance, I looked into some super wide zg fender flares for the Datsun 240z and don't mind chopping my legend since the body is too costly to repair I figured I would go with a hotrod kinda style.
But being conservative ill more than likely get the 7 wide, just checking out my options.
L3GDKANG/JDMKANG 03-09-13 08:35 AM
Well if you want wider rims with a drop check my teaser thread I'm running a staggered setup and I had my fenders pulled so I can drop with a tuck on my jdm legend.
G2coupes 09-08-13 09:11 PM
1 Attachment(s)
FORD EXPLORER FLEX FIVE HUNDRED TAURUS 17X7.5 OEM STOCK BLACK STEEL WHEEL
5 x 114.3 bore size is 63.4mm I think legend bore size is 70.2 my hopes are to bore this without any complications like running into the lug holes has anyone ever bored a stock steel rim before
jackjames898 01-17-18 01:07 AM
Recommended Tire Pressure
Just wanted to share a useful resource for those looking to find recommended tire pressure settings for their car model.
Hope this helps!
jackjames898 01-17-18 11:30 PM
Just wanted to share a useful resource for those looking to find recommended tire pressure settings for their BMW model.
BMW Tire Pressure
Hope this helps!
