what do I have to do to fit 20s on my 02 RL? - The Acura Legend & Acura RL Forum
Old 09-14-06, 12:34 PM   #1 (permalink)
Car 1: 2002 Acura 3.5 RL w/o Navi
I want to put 20s on my 2002 RL. How can I make them fit?
Ill put them on 225/35/20 or will 225/40/20 fit? I want to maximize ride comfort (which i know is tough with 20s), but I also want to make sure they dont rub at all and that I'll still be able to seat 4 people in the car.
what can I do??
Thanks guys!
JCMoney2002 is offline   Reply With Quote
Old 09-14-06, 05:06 PM   #2 (permalink)
iTrader Score: 24 reviews
buy an suv.
Old 09-15-06, 01:06 PM   #3 (permalink)
springs
i just got my struts done and i was going to put my 20's on. the shop put them on but due to the springs they would not fit with out rubbn i'm tryn to figure out a spring that is taller so they will fit rub free ! if you find out another way from what this shop tells me let me know cause dam this car looks good on dubs
jreelo4 is offline   Reply With Quote
Old 09-20-06, 07:17 PM   #4 (permalink)
aftermathacura's Avatar
Car 1: 96 acura rl
Car 2: 95 s420 benz
Car 3: 96 acura rl
you will need to find a 20x7.5 rim and go with a 30 series tire.
aftermathacura is offline   Reply With Quote
Old 09-21-06, 04:02 AM   #5 (permalink)
offset???
J Witherspoon is offline   Reply With Quote
Old 09-21-06, 01:10 PM   #6 (permalink)
on my car, 20x8.5 with 225/35r20 tires and i rolled the fenders!
NO RUBS!!!!!!! HAHAHAHA
ELPAISA is offline   Reply With Quote
Old 09-21-06, 01:14 PM   #7 (permalink)
here is my car!!!
Old 09-21-06, 04:56 PM   #8 (permalink)
its nice that you guys are giving him sizes and widths of your wheels and the sizes of your tires, but that doesnt mean anything without the proper offset
Old 09-21-06, 05:31 PM   #9 (permalink)
have them test fitted b4 you buy them. you wont buy a pair of jeans without trying them on?!?! i was thinking of buying mine online but i read that these people would buy them, not fit or rub on the caliper/fender and sell them right away!! i had to travel about 1 hour to joliet to have them fitted! it was worth the drive. plus it was a nice day out. so i would say find a place that will let you test fit the rim and tire package.
Old 09-22-06, 04:15 AM   #10 (permalink)
so what offset do I need???!!!
Old 09-24-06, 01:57 PM   #11 (permalink)
DMB
Do you have the name and number of that place in Joliet? I'd like to stop and check it out.
Thanks
DMB is offline   Reply With Quote
Old 10-05-06, 02:11 PM   #12 (permalink)
hey i just got back from mexico! but i willl look for that number and let you know!
Old 03-15-07, 12:55 AM   #13 (permalink)
offset
you can get offset info online from some wheel shops. . . say 42-45 ml on a 7.5 width wheel. my 99 rl roles on 20x7.5 wheels with 45 offset and doesn't rub and unrolled fenders too. if i had a choice, i'd go for 55-65 offset (65 being factory i believe), but good luck finding an alloy you like that has that kind of offset. . .
abim is offline   Reply With Quote
Old 03-15-07, 12:24 PM   #14 (permalink)
B+O
I'van der Rohe
Towers of Hanoi Champion
B+O's Avatar
Car 1: why?
Send a message via AIM to B+O
what kind of wheel is it ELPAISA. The offset information should be freely available on the interweb.
you guys are going WAY too conservative on these sizes for an 99+ RL you can stuff an 8" under there with a 40mm offset lowered! if you're not going to lower you can do an 8.5.
Typically i would look for anything above 38mm with an 8" wide wheel. Don't buy the 7.5" just get an 8 and be done there's plenty of 8s out there with 40+ offsets.
you'll be happier you did the 8 with the extra rubber under the car. more weight distributed across the tires, better tire wear, and if you do it right, with the right tire purchase, you can have a smooth ride.
Old 03-15-07, 07:07 PM   #15 (permalink)
you are right on B+O.
just to give some of you an idea of how far off some of the suggested wheel sizes are:
My 97 q45 has a suggested wheel size of of 19x8.5 via 42 offset with a suggested tire size of 245 40 19. Keep in mind this is tirerack's recommendation.
(Tirerack doesn't even offer a 20" for 1997 q45 . This means according to them it will not fit.)
I am running 19x9 +13 at the front (3 inch of real lip) with 245 40 19 and lowered about 2 inches.
guess what ? NO RUB. There is a difference of about 30mm-45mm
Choose your wheel sizes wisely.
91LegendCoupe is offline   Reply With Quote
I thought you guys said that 20's couldnt fit? midwestlegend Second Generation Legend (1991-1995) 13 04-07-04 04:49 AM
How Do I Fit A 20 Inch Rim On My 91 Ls Sedan??????????????????????????????????? imaculate1 Second Generation Legend (1991-1995) 43 01-06-04 04:22 AM
20's will fit for those who say they won't Gerald Second Generation Legend (1991-1995) 18 11-10-03 11:42 AM
What needs done to fit these 20's on? Henyaman Second Generation Legend (1991-1995) 12 12-09-02 04:16 PM
any V6 honda engines that can fit? Van Second Generation Legend (1991-1995) 3 05-05-02 03:08 PM
