Wheel shake, under load, while turning. - The Acura Legend & Acura RL Forum
Old 05-01-12, 04:37 PM   #1 (permalink)
Car 1: 1991 Legend LS
Car 2: 1991 Legend LS (#2)
Sorry guys, I searched but couldn't find a definitive answer on this and maybe there isn't one, but...
The front wheel on my 91 LS feels loose, shimmies, whatever, while accelerating into a turn. My dealer suggests replacing the axle "first" (i.e., they're not sure what's wrong).
Any suggestions? They've inspected the front end and this is what they've come up with.
Diamonddave is offline   Reply With Quote
Old 05-01-12, 08:36 PM   #2 (permalink)
BIGBOY's Avatar
Car 1: 94 acura legend ls
It can be a axle or a bearing, jack the car up and check for play @ 12 & 6 than 3 & 9. I there isn't any play replace the axle.
Old 05-01-12, 10:25 PM   #3 (permalink)
Car 1: Honda legend 86 KA1
Car 2: Honda civic en1 84
Car 3: Ford laser gf 91 wag
hey just a quick note that wouldnt be a buckled rim would it i had something similar to that and thats what i found just an idea of a possibility (for steel rims)
legendlover11 is offline   Reply With Quote
Old 05-01-12, 11:00 PM   #4 (permalink)
The dealership jacked the car up and tried to replicate the problem but without a load, the test came up empty. They said the only apparent issue is the excessive play in the axle. I'm going to give them the green light to replace it tomorrow and only with an OEM axle. I'll let you know what happens and thanks for the comments.
Old 05-01-12, 11:56 PM   #5 (permalink)
Another 3.5er
Car 1: Gold '95 G2 Acura Legend L Sedan
Send a message via Yahoo to JonsLegend
Sounds like an axle to me
a 3.5 hybrid 6 speed by the end of this week...
[SIGPIC][/SIGPIC]
JonsLegend is offline   Reply With Quote
Old 05-03-12, 11:19 PM   #6 (permalink)
The new axle did the trick. No more wheel shake!
Old 05-05-12, 01:46 PM   #7 (permalink)
BIGBOY's Avatar
That's good.
Old 06-29-12, 09:55 AM   #8 (permalink)
i searched on here, havent found anyone else with just shaking under acceleration that was unbalanced wheels. is there anything else i could look at while removing the wheels? I had the same problem because I'm an idiot and forgot to tighten my driver's side lugs enough. I re-tightened them and it stopped shaking, but then they came loose again. It turned out I had to get new studs because they were stripped.
I'm just happy my wheel didn't fall off. Make sure your lugs are tight again. Your studs could be stripped and your lug nuts could be getting loose again. It could be dangerous!
Performance Chip
jaylin is offline   Reply With Quote
Old 03-06-13, 05:41 AM   #9 (permalink)
It's really good to know that your problem is resolved. How much did the new axle cost you? I am facing a similar problem with my Honda, and my mechanic is suggesting me to go for a Used Axle. Would it be feasible to buy a new axle or get it replaced by a used part? Please suggest.
Get used parts here http://www.automotix.net/usedautopar...inventory.html
Hadley-Lucius is offline   Reply With Quote
Old 03-06-13, 08:04 AM   #10 (permalink)
Car 1: 1992 KA7 - 5 SPD - BLK/TAN, Frost White
If money isn't a problem for you go with an oem, I had similar problems and went to a pick n pull for a used axle, only costed me 20 bucks and a lifetime replacement used axle from the yard if it fails. haven't had a problem since
WickedShepard is offline   Reply With Quote
