-   Wheels, Tires, Brakes, and Suspension (https://www.acura-legend.com/vbulletin/forumdisplay.php?f=94)
-   -   Will this setup work? (wheels) (https://www.acura-legend.com/vbulletin/showthread.php?t=80320)
kostas86 03-21-06 11:43 AM
I am looking at putting some 18s on the legend.
The wheel I am looking at has the following specs:
18x7.5 5-100/11438SM
Also if I go with a 245/40 tire will it rub?
Thanx!
Also do you think a 6-spoke design will look nice on a Legend?
BTW if I do decide to go with this setup, my 17" Enkei RSVs will be up for sale.
Hotstartup 03-21-06 12:10 PM
offset?????????????
kostas86 03-21-06 12:57 PM
It's a 38 offset
go92Legend 03-21-06 02:59 PM
Originally Posted by kostas86
It's a 38 offset
Nope, Dino. Don't think it will work. At 7.5 width, the offset is too low (numerically). It will stick out. My rims are 17x7.5 and +48 offset and pretty near the edge. I'd say 45 offset is as low as you could go with 7.5 width.
mYbabYLeGend 03-21-06 03:03 PM
i got 45 on my 18x7.5 225/40/18, i barely get away with it in the back.
-hass
whyteLegend 03-21-06 03:10 PM
I have 18x7.5 with a 38 offset, the 245's will rub because my 225's rubbed when I ever hit bumps with weight in car . I however rolled my fender last month & can't wait to put them back on plus I will be lowering too (when weight was in the car the tire would tuck under the rear wheel well and I like that look).:yes:
mYbabYLeGend 03-21-06 03:11 PM
Originally Posted by whyteLegend
I have a 38 offset, the 245's will rub becuase my 225's rubbed when I have hit bumps with weight in car . I however rolled my fender last month & can't wait to put them back on plus I will be lowering too (when weight was in the car in would tire would tuck under the rear wheel well and I like that look).
Damn you rubbed without lowering? Good luck dude
-hass
whyteLegend 03-21-06 06:01 PM
-hass
I only rubbed with a lot of wieght I was taking my mom to the airport (in NY bumpy roads) and the truck was loaded to max, plus three persons in the back. Otherwise I was fine it cleared the finders perfectly + I rolled my fenders now that = more room .... lowering soon :fart:
kostas86 03-22-06 01:40 AM
Thanx for the info guys!
I'll continue to shop around seeing I am in no hurry.
It looks like my insanity for deep lips won't be fulfilled on the Legend:giggle:
amplified 03-22-06 01:40 AM
^yup unless you do a widebody
kostas86 03-22-06 01:45 AM
Temptation!:yumyum: :giggle:
I am so used to the offsets for mercedes and the Z that I tend to forget that Acura isn't soo generous.
After I traded in my 05 Z for an 06 Z, I sold my deep dish enkei wheels for deeper and wider wheels (i know it's this sickness i have) in hopes of getting the rear tires 295 if not 305 on a 10.5" width, I'll know by friday.
So I then figured, why not give the Acura a shot at going wider, I'll take it to a few shops and see what they can do.
RangerJoe 03-22-06 02:19 AM
I don't understand why people think the legend is so difficult to buy wheels for. Someone has bought everything you can think of. You've been here long enough to have seen a thousand threads about wheels.
kostas86 03-22-06 02:47 AM
Because our offsets suck, and I want the deepest lip I could get without rubbing so it tends to be a hassle when trying to go wide.
Just in case you don't know, I hate no lip/small lips.
Hell. if I could, I would run a staggered setup but it's pointless seeing I can't fit anything real wide in the rear.
I've tried calling a few places like DTD and Tire Rack but they tell me not to go over 8" width, so I am trying to get a second opinion from others.
Gride_Cruiser 03-22-06 03:11 AM
Hey Kostas, maybe you could take a look at Axis wheels? They play around w/ high disc and low disc to give the staggared look with same width wheel front and rear. http://www.axiswheels.com/wheels/decade/decade.html The offset I remember from asking Axis are 18 by 8 via 40 + offset, still a little bit too low for the Legends, but rolling fenders could be the remedy. I know the design isn't too great, but maybe you could consider it.
kostas86 03-22-06 03:15 AM
Thanx!
Definitely something I'll keep in my mind!:thumbsup:
Hopefully they might come out with a nicer design.
