would these aftermarket rims made for rsx fit? - The Acura Legend & Acura RL Forum
Old 07-28-06, 01:06 PM   #1 (permalink)
rims in question is a set of Work XT7 in 17*7 with 47 offset. the only concern i have is the center hub. Since stock RSX rims need to be bore out to fit the legend, will i have to do the same with these?
thanks
Team_mclaren is offline   Reply With Quote
Old 07-28-06, 02:22 PM   #2 (permalink)
iTrader Score: 24 reviews
yes most aftermarket RSX wheels will fit on a legend. However you will still have to bore out the center bore to fit them on.
Old 07-28-06, 05:35 PM   #3 (permalink)
hmm shit, will it be able to fit an rsx again after I get them bore out?
Old 07-28-06, 05:40 PM   #4 (permalink)
yes, you just have to get a rubber or metal hub centric disk put into the bore, infact some members like to bore the rims to 71-74 and then get a 70.2 insert put in. same can be done to revert it back to stock (65ish)
Old 07-28-06, 05:44 PM   #5 (permalink)
is gone with the wind ...
go92Legend's Avatar
Car 1: '92 Vineyard Grey LS Sedan
Car 2: '05 TSX Gray auto
Car 3: '08 MDX Steel Blue/T
thanks
I don't think these aftermarket wheels are "RSX specific". If you look at the Work website they are pretty generic and available in a number of sizes. My expectation is that the hub bore is 73.1 mm which is pretty standard for aftermarket wheels and that you will actually require a hubcentric ring (73.1OD/70.1 ID) to maintain center and relieve lug pressure. Call the distributor and simply ask the internal bore of the wheel before buying. They have that info.
--Gerry
"All opinions expressed above were left over after the good ones had been taken..."
go92Legend is offline   Reply With Quote
Old 07-31-06, 09:15 PM   #6 (permalink)
go92legend is right, its likely that the bore size is 73mm as an aftermarket wheel. that's why they sell hubcentric rings.
amplified is offline   Reply With Quote
20X7.5 rims that may fit RL with lowering praymant First Generation RL (1996-2004) 5 05-27-05 11:26 AM
Will these rims fit on my 90 Coupe aminus21 First Generation Legend (1986-1990) 4 04-25-05 04:46 PM
'04 Acura TL rims fit? GoBruins Second Generation Legend (1991-1995) 3 10-07-04 03:41 PM
Will rims from Legend fit 3.5RL ? BIG BOSS First Generation RL (1996-2004) 1 06-18-04 02:58 PM
I pray these Rims fit... alboogie Second Generation Legend (1991-1995) 6 04-24-03 06:18 PM
