ECU Codes and what they mean...G1 & G2 - The Acura Legend & Acura RL Forum
» Auto Insurance
» Wheel & Tire Center
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 02-27-02, 08:35 AM   #1 (permalink)
502MotorSports.com
502 MotorSports's Avatar
Car 1: e39 540i | e28 533i [Euro]
Car 2: e60 530i | e46 330i
Car 3: S430
Send a message via AIM to 502 MotorSports Send a message via Yahoo to 502 MotorSports
Post ECU Codes and what they mean...G1 & G2
Some useful info:
Getting that little Check Engine lights on your dash may seem a little discomforting. In reality it is really a miracle of engineering and computer technology. Instead of randomly pocking in vast amounts of wires, sensors, and mechanisms in such complex car as a Legend, this little light tells you that your computer knows exactly what is wrong with the car (most of the time).
That means the exact sensor or gate has been pin-pointed as being either partially disconnected or simply out of acceptable range.
Location of ECU on 1986-1990 Legends
The control unit is located under the passenger seat on sedans and under the passenger foot well carpet on the coupes.
The engine CPU is the form of an aluminum box with a little plexiglass window. All you have to observe is a little red LED.
Location of ECU on 1991-1995 Legends
On the 1991-1995 Acura/Honda Legends, you have to jump a service connector located on the passenger side right under the dashboard near the door. The connector has two pin inputs. Connecting them with something like a paper clip will force the check engine light on the dashboard to display the codes.
Extracting Codes
With the car either running or the key in the ON position, perform the necessary steps above and observe the blinking of the light. The light will blink displaying all the codes in sequence and then repeating them.
Reading Codes
The code numbers are read by counting the number of blinks between longer pauses. On 1986-1990 Legends, the code number is indicacted by a series of rapid LED blinks between longer pauses.
On 1991-1995 cars, codes 1-9 are indicated by a series of short flashes; two digit codes use a number of long flashes for the first digit followed by the number of short flashes for the second digit. So a code 43 will be represented by 4 long and 3 short flashes.
The position of codes in a sequence can be helpful in doing diagnostics. A display showing 1-1-1-pause-9-9-9 indicates two problems occurring at different times. A sequence showing 1-9-1-9-1-9 indicates two problems occurring at the same time.
Resetting ECU
Sometimes it may be useful to reset the ECU memory. Although that maybe done by removing the battery for around 20 minutes or so, this will also kill your clock and radio presets. A more elegant way is to:
on 86-90 Legends remove the alternator fuse for 20 seconds.
on 91-95 Legends remove the ACG fuse in the interior fuse panel for 20 seconds. (note that this will also clear the seat memory)
Below are trouble codes for 86-95 Acura/Honda Legends:
1986-1990 Legend (G1)
Code # Explanation
1 Front Oxygen Sensor
2 Rear Oxygen Sensor
3 Manifold Absolute Pressure Sensor
5 Manifold Absolute Pressure Sensor
4 Crank Angle Sensor
6 Coolant Temperature Sensor
7 Throttle Angle Sensor
8 Top-Dead-Center Position Sensor
9 Number 1 Cylinder Piston Position
10 Intake Temperature Sensor
12 E.G.R. System
13 Atmospheric Pressure Sensor
14 Electronic Idle Control Module
15 Ignition Output Signal
17 Vehicle Speed Sensor
18 Ignition Timing Adjustment
1991-1995 Legend (G2) (Click here for transmission trouble codes)
Code # Explanation
1 Left Oxygen Sensor
2 Right Oxygen Sensor
9 Number 1 Cylinder Position (No. 1 Sensor)
12 E.G.R. Sensor
16 Fuel Injector
23 Left Knock Sensor
41 Left Oxygen Sensor Heater
42 Right Oxygen Sensor Heater
43 Left Fuel Supply System
44 Right Fuel Supply System
45 Left Fuel Metering
46 Right Fuel Metering
53 Right Knock Sensor
54 Crank Angle 2 Sensor
59 Number 1 Cylinder Position (No. 2 Sensor)
502 MotorSports is offline   Reply With Quote
Old 02-27-02, 08:38 AM   #2 (permalink)
*r**h *eller
Car 1: 07 TSX
Car 2: 08 Odyssey
Car 3: The roller skate
iTrader Score: 1 reviews
Send a message via AIM to Dave C ver2.0 Send a message via Yahoo to Dave C ver2.0
Thumbs up
We're gonna sticky this one also.
I like my little red roller skate.
Dave C ver2.0 is offline   Reply With Quote
Old 02-27-02, 10:39 AM   #3 (permalink)
thanks leon now i have a so called "cheat sheet without pulling out the book.
93typeII is offline   Reply With Quote
Old 02-27-02, 02:47 PM   #4 (permalink)
502MotorSports.com
Car 3: S430
My pleasure guys
Old 02-27-02, 07:02 PM   #5 (permalink)
Guest
Posts: n/a
Are these codes need for when you get the Stage II chip?? Or Just if you senn the check engine light flashing..
Old 02-28-02, 09:40 PM   #6 (permalink)
502MotorSports.com
Car 3: S430
no..these are f you get a check engine light and you retrieve the codes as stated above....G2 is set up differently from G1
Old 03-10-02, 12:14 AM   #7 (permalink)
FutureX 2001's Avatar
Car 1: '95 Coupe
Car 2: '94 Sedan GS
Car 3: '90 Coupe
iTrader Score: 3 reviews
Send a message via ICQ to FutureX 2001 Send a message via AIM to FutureX 2001 Send a message via MSN to FutureX 2001
Do any of the tranny lights ever flash to give codes too? Just curious... On the AT
FutureX 2001 is offline   Reply With Quote
Old 03-10-02, 12:20 AM   #8 (permalink)
GS Hog
Golden Arrow Champion
LegendGS's Avatar
Car 1: 1994 Legend GS-Auto
Car 2: 1994 Legend GS-6 spd
Car 3: 1993 NSX-6 spd
iTrader Score: 2 reviews
I belive that the D4 light flashes for tranny codes.
LegendGS is offline   Reply With Quote
Old 03-10-02, 09:18 AM   #9 (permalink)
This info is GOLD. Thanks Leon
CakeDaddy is offline   Reply With Quote
Old 03-14-02, 03:17 PM   #10 (permalink)
thanks much bro on this info heh, now i can find otu exactly why that light is on, it came one yesterday and got me curious, i think i might have blowin a fuel injector, but not really sure, the pcm-fi light is on, and thats the check engine light on 86 acks, well thanks
biggdave15 is offline   Reply With Quote
Old 03-15-02, 03:02 AM   #11 (permalink)
502MotorSports.com
Car 3: S430
Hey guys, I am glad to help. That is what its all about. Good luck with your troubleshooting. If you don't have a Helm's I suggest getting one - http:/www.helminc.com
Old 03-26-02, 07:43 AM   #12 (permalink)
Thanks for the info.
Priceless.:cool:
Rusky is offline   Reply With Quote
Old 04-07-02, 01:18 AM   #13 (permalink)
very sweet info man, btw how long does the light last?, any way to tell if it's burnt out?
flashdragoon is offline   Reply With Quote
Old 04-27-02, 03:54 AM   #14 (permalink)
Guest
Posts: n/a
What exactly is the benefit of reseting the ECU though? I haven't done it since I did that CAI, should I do it now or would it be pointless?
Old 04-30-02, 08:02 PM   #15 (permalink)
I have a g2 91 sedan and i don't see an ACG fuse, all i see are ALB fuses thats the closest thing to ACG i can see. Can anyone show me a picture or a chart or something
Trixiem is offline   Reply With Quote
Powered by vBulletin®. Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
