A/C Cabin filter change/removal tutorial w/ pics. - The Acura Legend & Acura RL Forum
Auto Insurance
Wheel & Tire Center
Old 06-05-03, 02:47 AM   #1 (permalink)
OK i have read the other threads regarding changing the cabin filter and have tried to use them to change my filter but had a problem b/c there were no pictures & only brief descriptions.
Even the Helm manual told me to remove the the glove box frame which was a waste of time b/c there are alot of screws and you don't have to do this. Nor do you need to remove the glove box side covers.
Here is my tutorial for any one else who needs to change their cabin filter and I have included pictures to make your life easier.
Step 1
Remove the three plastic screws & the glove box lower panel & disconnect the connector from it.
Step 2
Remove these 2 screws on each side of the glove box bottom.
Step 3
Then pull down the cloth trim inside the glove box. Next remove the glove box light connector.
Step 4
Disconnect the string behind the cloth trim. Be careful not to break it, this string prevents the box from dropping down hard when you open the glove box.
What I did was I carefully pry off the loop from the bracket.
Step 5
After you remove the glove box, this is what you see. The cabin filter is behind the green and gray plugs.
Step 6
Disconnect these plugs & move the plugs out of the way and remove the screws holding the filter bracket and pull out the filter.
Clean and/or replace the filter. You'll find a lot of leaves and junk when you pull out the filter. Use a vacuum and clean the inside area of where the filter was. Then turn on the blower to circulate all the dust that are trapped in between it.
And wa-la you're done. Installing it is in the reverse order. I hope that this will help some of you.
Flounder is offline   Reply With Quote
Old 06-05-03, 04:01 AM   #2 (permalink)
Car 1: 1993 Legend LS sedan, 2002 3.2TL
iTrader Score: 1 reviews
Send a message via AIM to PerzianKabob
awesome.....i'm gonna give this a try this weekend, and maybe i'll try adding a better filter based on previous threads.
PerzianKabob is offline   Reply With Quote
Old 06-05-03, 04:37 AM   #3 (permalink)
Car 1: 94 Milano Red Coupe L
Great Job! I love to see people doing this kind of stuff! This is what helps to make our forums better and is what we should be concentrating on.
1994 Acura Legend Coupe
SpeedDemon is offline   Reply With Quote
Old 06-05-03, 12:25 PM   #4 (permalink)
4ever & ever & ever ever
Car 1: 1991 Frost White Legend Sedan L
Send a message via AIM to Legend4ever
nice tutorial, i tried it yesterday but i gave up after i was unable to remove those 4 screws, they were like welded on, oh well ill give it another shot.
"F*** popo, we blowin dro out the ack legend"
[email protected]
http://www.photohost.org/gallery/dat...4ever_Sig2.jpg
Sig By KnO12TrUsT
My Car is for sale, check in legends for sale section........
Legend4ever is offline   Reply With Quote
Old 06-05-03, 03:13 PM   #5 (permalink)
K L E A N M O D
Thai.95LCoupe's Avatar
Car 1: 1995 KA8 *R.I.P*
Car 2: 1997 S14 *SOLD*
Car 3: 2004 GTO
iTrader Score: 8 reviews
Ima do this filter change soon.
-1995 KA8 MODIFIED-R.I.P
-1997 S14a-SOLD
-2000.2 Millenia S- Blown & SOLD
-1996.8 S14a-SOWED
-1995.8 S14a- SOLD
-2004 GTO-R.I.P
-1998 S14a
-Holy Rollerz CCC Member-
My KA8's totaled and still greater than....
Imitatated. Never duplicated.
Thai.95LCoupe is offline   Reply With Quote
Old 06-22-03, 11:35 AM   #6 (permalink)
Honda 4 L*fe
Car 1: 94 Coupe L -- Sold 8/04
thanks for the pics. they made the job that much easier. only problem i ran into was that someone had pop-riveted the lower plastic panel on so i had to drill them out. man was i pist.
i couldn't believe all the debris in there. there where even bird feathers!! New filter, lysol and and hour later my cabin air was magnificent. Great DIY job. do it
CBRKid20 is offline   Reply With Quote
Old 07-11-03, 01:29 PM   #7 (permalink)
THANK YOU FLOUNDER
I just did the Filter clean out, you DIY instructions are the best. Thanks for taking the time to do this. I lot of junk can cumulate in 10 years, now I want a better filter. Thanks again, this was very easy to do!
Lilspanisheddie is offline   Reply With Quote
Old 07-11-03, 07:26 PM   #8 (permalink)
Re: THANK YOU FLOUNDER
You are very welcome. I have learned a great deal of info from some of the "Legend Masters" on this site and just wanted to share like everyone else.
Keep those tutorials coming.
Old 07-22-03, 02:29 AM   #9 (permalink)
Stock Is Best
7up Pinball Champion, Grid Game Champion
Mastervtec's Avatar
Car 1: Bastard People
iTrader Score: 3 reviews
Send a message via AIM to Mastervtec
Just did this thanks to your tutorial!! I spent about 30 minutes getting that bottom screw back in, the one that holds/seals the filter in there. Thanks!!
-BDE
"I like your cane." <<< >>> LMAO. You had to be there.
CLICK!!>>> Newbie FAQ...Read It!! <<< CLICK!!
My Coupe - Sold
My New Coupe
Mastervtec is offline   Reply With Quote
Old 11-27-03, 01:21 AM   #10 (permalink)
theGodfather's Avatar
Car 1: 1995 Carbon Black Metallic 6-Speed Coupe
Car 2: 2007 Audi A6 4.2
iTrader Score: 2 reviews
Is this filter only for the "A/C" or is it for the entire climate system (even when the heater is on)?
1995 Legend Coupe 6-speed
208 WHP @ 6250 RPM
189 FT/LB @ 5250 RPM
MUSTANG Dyno
260,000mi and counting
WeaponR Secret Weapon Intake - Cold Air Box - Custom 2.5" stainless exhaust system - Remus Rev3 Universal muffler -SPEC Stage II clutch - 5speed flywheel - SR5GUY Chip - APEXi S-AFC - Pullies - MLS copy strut bar - Short Shifter -18" ICON W65 Wheels - KONI reds/Ground Controls - Slotted Brembo Rotors - SS Brake lines - Walbro 255 -ICE
theGodfather is offline   Reply With Quote
Old 11-27-03, 03:48 PM   #11 (permalink)
The filter should be for the whole system. Whenever you turn on the blower (heat or AC) the air will pass through the filter toward the cabin.
Old 11-29-03, 02:29 PM   #12 (permalink)
why does mine always have to be harder? w.t.f.? ok.. so, i pulled it all apart, no problems.. but i dont have a green plug back there :-( and things look different from those pics for some reason.. and well, it started getting too cold for me outside so i cleaned out what i could cuz it was nasty under there and put everything back together... so, after my defensive driving class tommorow, ima go back at it. i guess i'll let yall know how it goes then.
ImportGrl is offline   Reply With Quote
Old 12-06-03, 08:49 AM   #13 (permalink)
I know you don't see the green plug...I didn't have it either...well you will have plugs back there they will be gray...well they are on a bracket a metal one you can see it right behind the green plug..well there are 2 phillips screws one on the top and one on the bottom of that bracket take them out then the filter will be behind that metal bracket that is holding up all those connectors.
xsuperjoex is offline   Reply With Quote
Old 04-15-04, 09:37 PM   #14 (permalink)
Car 1: 93 legend dark green sedan
hi guys
keep up this good work and we will never have to pay for those things again
legendlov93 is offline   Reply With Quote
Old 04-25-04, 12:51 PM   #15 (permalink)
Car 1: 1991 Blue Sedan
Send a message via AIM to abcheng
i believe the green connector is for LS models, with the climate control. If you need me to, I can take pix of my car with the gray connector only.
abcheng is offline   Reply With Quote
