Crazy Cuban's Guide TO Custom coupe clear/red taillights - The Acura Legend & Acura RL Forum
» Auto Insurance
» Wheel & Tire Center
Old 06-12-03, 09:51 PM   #1 (permalink)
3D Car Driver Champion, 5 In A Row Champion, Astro Cave Champion, Battle Bots Champion, Break Into The Crowd Champion, Blackjack Champion, Gates To Bleed 2 Champion, Playing With Fire Champion, Buzzgame Champion, Day In The Park Champion, Dragon Force Champion, Flying Gonzo Champion, Gem Mania Champion, Jail Bird Man Champion, Long Jump Lite Champion, Lunar Mouse House 2 Champion
Cool Crazy Cuban's Guide TO Custom coupe clear/red taillights
ok, This is going to my thread on how I made my taillights so I can stp getting all the "How did you do that?" and "Can you make me a set?" questions.
Not that I don't like all the comments and everything. It's just tired of typing the same resonses over and over and ....
What you'll need:
Extra set of taillights (A MUST if you plan on selling the car or need to put the stocks back for some reason)
Sheet of Plexi or equivalant that's about 1/4" (I used something called Plasticlite because I could find plexi)
Sheets of paper, marker, and scissors (any paper that is bigger than the lense will work fine)
Clear silicone epoxy (for sealing up the lights water tight)
Putty knife or Ice scrapper (trust me, just read on)
Aluminum foil and/or cookie sheet
Dremel or any tool that cuts plexi cleanly (I used a dremel with a diamond cutting wheel)
Testers Candy Apple Red Trasperant paint ( I found mine at a local hobby shop, comes as a spray)
Masking or painters tape
Scuff pad (I got it at the Auto store in the paint section)
Clamps that won't melt (old metal ones are the best)
Heat gun
Knowledge of how to open lights (if you search the forum you'll find the info. *I used 300 degrees for 10 -15 min.*)
TIME AND DESIRE TO GO ALL THE WAY!
Step one: Take the tails, one at a time, and place them on a piece of aluminum foil and make sure you prreheat the oven first.
Side note: now would be a perfect time, while it's pre-heating, to take as much as you can off the taillights ex: screws, rubber, etc.
Once, they are good and warm take them out *CAUTION HOT* and slowly pull them apart. Use a wide putty knife or a ice scrapper and use it like a screw driver to help seperate the tailligh tring to pry as evenly as possable. If the Glue becomes not as guey (sp?) just place them back in the oven to rewarm and continue. *Remember the light WILL brake if you pull unevenly*
Side note: I broke my pass one durring this proccess. DOH!
Ahh you have them apart. Good. You can now move on (all you that broke them can move on as well just see the *alternative below*)
Step two: *This is the most IMPORTANT part if you want perfect sized taillights* This is also where you'll need thoughs skills from Kindergarden. Take a piece of paper and trace one of the lenses anyway you choose. I traced mine with them flat on a table and traced them like we all did with our hands to make thoughs turkey drawing. (ok, maybe that was just me) Then cut them out and place it on the plexi sheet to trace them. To get the other side just flip the "pattern" over and trace it again. Now feel free to cut them with that dremel or rotozip thing.
Step Three: Place them on top of the bezels and clamp them down to the bezels nice and tight. Clamp them so the plexi lenses are EXACTLY the way you want them too be. Now, take that heat gun and heat up the plexi as hot and evenly as you can without melting anything and make sure thoughs clamps are on there tight. Once you've done that set them aside to "air cool" for about 24 hours.
So, by now you can remove the clamps but if they try to go un curve, REPEAT STEP THREE. They need to stay the right way before you seal them or over time they WILL leak water.
Step Four: I'm impressed you made it this far. Good for you. The hardest part of making your custom tails is almost over.
I kept a couple of clamps on the lense to hold them in place. Take you marker and mark the borders to where you will paint. I marked a line accross the taillight in the center for the bottom red section and also followed the border of the chrome for a border to cover the silicone. Good drawing skills. Now, take them off the bezels, flip them over, and tape off everything you DO NOT WANT PAINTED! DO NOT PRIMER! Just lightly scuff the back where the paints going with a light scuff pad. Now wipe it clean with a damp rag water only is good) to get all finger prints and residue off. Let them dry. Spray them with about 3-4 light coats (follow the directions on the back of the can). You can, as an option, spray some clear coat on the entire inside of the lense with the tape removed for an extra shine. Let them dry for at leat another 24 hours.
Step Five: Now take the lenses an clamp them on the bezels again. Take the clear silicone (I used one of those guns and a tube to do this part) and put a THIN bead around where the lense and the bezel meet. LET IT DRY FULLY! Then repeat once dry until you fill the space between them.
Once you have it filled, you can shape the edge to match the "stock look" or leave it to get a better custom look.
OPTIONAL Step Six: Use some rubbing compound on the outside of the lenses. Then buff them like you would with the headlight tip. Once they look perfectly clean/clear you can add a few thinly palced coats of clear coat to keep them looking "new".
CONGRATULATIONS YOUR DONE.
*Alternative* If you have broken them.
Keep in mind to reference the above to fil in the gaps. I am just telling what's different here.
Cut off the amber section using a dremel. Use your bezel instead to trace the taillight size making sure add about 1/4" to 1/2" outside of the chrome to ensure the right size. Use the same heating as in "STEP THREE". Now glue the section you want to save together and place on the bezel. Take the plexi and place on top of that and make sure the edges meet up best you can. Cut and sand them to match as best you can. Simply silicone them together now. The rest is the same as STEPS FOUR on.
Pics to come later. If someone else doesn't do it first. Sorry for all the gramer and spelling errors.
ohh and Your ALL welcome.
Crazy Cuban is offline   Reply With Quote
Old 06-12-03, 10:16 PM   #2 (permalink)
Car 1: 1991 Cobalt Blue KA8 (sold)
Car 2: 1998 Kouki (sold)
Car 3: 1994 Desert Mist KA8
Send a message via AIM to Gerald
Good write-up!!!!!.......
........I learned this method of clearing tail lights from tha '90-'93 Integra club I was apart of
http://img.photobucket.com/albums/v502/acura_lover_85/Best-Night-Pic23again.jpg
Help Me Find White/Black KA8
Gerald is offline   Reply With Quote
Old 06-12-03, 11:42 PM   #3 (permalink)
thanks!!!! excellent tutorial
bklynstunna is offline   Reply With Quote
Old 06-13-03, 12:24 AM   #4 (permalink)
Cant u just make me a pair and I will buy them from u?
skate4volcom007 is offline   Reply With Quote
Old 06-13-03, 03:47 PM   #5 (permalink)
Thanks so much, Great Info
But I with Skate4, can we send you pair of taillights and charge us for it. I work almost 80 hrs a week, I have no time but really like the look. Thanks
jedmund1 is offline   Reply With Quote
Old 06-13-03, 07:24 PM   #6 (permalink)
Thank you all .. I have been giving thought to making them .. but it does take a long time and I am going to attempt to make another set .. it that goes well .. then I should be able to make more .. just gotta find the time too
Old 06-13-03, 08:02 PM   #7 (permalink)
I completely understand about the time issue! Just let us know when you would be ready! If you need a set of tail lights, I got an extra pair
Old 06-13-03, 11:22 PM   #8 (permalink)
MLC
LEGENDARY MEMBER
MLC's Avatar
Car 1: 94 BLK/BLK COUPE
Car 2: 97 Altima GXE 5spd
Thanks crazy cuban, great write up. I am going to attempt this on my extra left tail. If it comes out good I will buy another right tail. I'll keep you posted.
JDM KA8 Headlights~McCulloch 5300k HID~Fiberglass Eyelids by PJ~JDM KA8 Door Sills~K&N Intake w/OEM CAB~Lightweight Pullies~Bayou Stage II Chip~Stromung B Pipe~Magnaflow Cat~Remus Spec Exhaust~Koni Kontrols~CL-S Type/Ventus 215/50/17~SS Brake Lines~Brembo/Bradi Rotors~DC Tie Bar~KMS Strut Bar~Addco Rear Sway Bar~S2000 Antenna~Shaved Trunk~Optima Redtop
MLC is offline   Reply With Quote
Old 12-18-03, 05:50 PM   #9 (permalink)
Car 1: 1992 Seattle Silver LS
Send a message via AIM to Matt Whelan Send a message via MSN to Matt Whelan
Where are the pics?
1992 Acura Legend LS Sedan
Car name: AL<---figure it out
http://www.imagestation.com/picture/...4/fd44ef6e.jpg
Modifications
GS Rims
Acura Gold Emblem Kit
OEM CD Changer
EDM Corners
BMW X5 Xenon Projector headlights
Xenarc Xenon driving lights
Custom Red/Clear/Red taillamps & JDM Red/orange/Red Taillights
6 color Indiglos
Black Mesh Upper Grill
Matt Whelan is offline   Reply With Quote
Old 12-19-03, 03:37 AM   #10 (permalink)
Car 1: Vertex Lexus RX330 Harrier
Car 2: Job Design Lexus GS3
Car 3: Widebody Lexus SC430
Send a message via AIM to Legendtoo
I'm down for a pair !!! Let me know .... I can send you my lights since my car will be garaged over the winter.
Mark
Legendtoo is offline   Reply With Quote
Old 12-19-03, 04:22 AM   #11 (permalink)
Car 1: 3.5L 1991 LS Coupe 5 Spd Blk/Blk
Car 2: 1999 Acura 3.5RL
Car 3: 2004 GMC Sierra Z71
iTrader Score: 5 reviews
Send a message via AIM to Mike Diaz
I will do this next summer. Can we move this to the DIY section when it gets a few days old?
Very nice tutorial.
Mike Diaz is offline   Reply With Quote
Old 11-24-04, 03:16 PM   #12 (permalink)
FutureX 2001's Avatar
Car 1: '95 Coupe
Car 2: '94 Sedan GS
Car 3: '90 Coupe
iTrader Score: 3 reviews
Send a message via ICQ to FutureX 2001 Send a message via AIM to FutureX 2001 Send a message via MSN to FutureX 2001
Did you ever make that 2nd set? or get pix?
I want clear/red tails =/
FutureX 2001 is offline   Reply With Quote
Old 11-24-04, 03:55 PM   #13 (permalink)
iTrader Score: 7 reviews
I have sedan tail lights forsale... 60bucks each or both for 100bucks. If you want to try this mod but need lights... send me a pm
Ballistic is offline   Reply With Quote
Old 08-16-05, 04:41 PM   #14 (permalink)
Outta GT
LEDG4F4's Avatar
Location: California/Stockton (Blk/Blk L Sedan (gone) Blk/Ivory GS)
Car 1: 1993 Black/Black L Sedan (gone)
Car 2: 1994 Black/Ivory GS
iTrader Score: 2 reviews
Send a message via AIM to LEDG4F4
Were pics ever posted of this mod?
RespEct A Legend
Legendary styling lives on forever!!!
http://i279.photobucket.com/albums/k...ndathome-1.jpg
LEDG4F4 is offline   Reply With Quote
acura-legend.com is an independent Acura enthusiast website owned and operated by VerticalScope Inc. Content on acura-legend.com is generated by its users. acura-legend.com is not in any way affiliated with Honda Motor Company.
Powered by vBulletin®. Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
