DIY Pics: Blower Unit Removal - The Acura Legend & Acura RL Forum
Auto Insurance
Wheel & Tire Center
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
Old 03-13-04, 09:20 AM   #1 (permalink)
Abtout a week ago I replaced my Blower motor and unit with a new one I bought from a forum member. Everything works well now.
I didn't take pictures through the whole process but hopefully these will still be helpful to people doing this themself.
my new blower unit.
removing the glovebox frame
remove these screws on the side to get the frame out.
where the cabin filter is (my 1991 didnt have one)
blower half out
unit is out, unplugging connections
thats all of the pics i took. sorry i dont have any pics of putting everything back together. the sun was going down and we were losing sunlight so i was in a hurry. its pretty easy, just remember where all of the wire harnesses and screws go! Keep track of them and label everything.
There are instructions HERE
Special Thanks to Tinkindling for letting us use his garage and tools and for all of the advice and tips!
Vancouver_Legend is offline   Reply With Quote
Old 03-13-04, 09:24 AM   #2 (permalink)
Type I King
Car 1: 92 LS Sedan
Car 2: 91 LS Coupe 5 spd
Car 3: 95 LS 6 spd coupe
iTrader Score: 7 reviews
Send a message via AIM to Hotstartup Send a message via MSN to Hotstartup Send a message via Yahoo to Hotstartup
again you see my hands in the pics!. lol..
Hotstartup is offline   Reply With Quote
Old 03-13-04, 12:44 PM   #3 (permalink)
To add to this, I took all the foam parts and replaced it ALL with brand new Automotive Weather stripping from Lowe's, even the doors. I also took a 3M filter (only lasts 3 mo. it says but oh well, I'm not changing that thing for another 3 years) and modled it where a filter for my 91 should be, It worked excellently and everything is airtight now.
Extrovertz is offline   Reply With Quote
Old 03-13-04, 01:55 PM   #4 (permalink)
Car 1: 1993 Acura Legend L (Sedan)
Car 2: 2006, Honda Civic Si
Car 3: 2005 Honda Odyssey
what about the srs?
hey sup,
what about the srs(airbag) did you disconnect them before start working on the unit??
thanks
Mandidy
Mandidy is offline   Reply With Quote
Old 03-13-04, 02:29 PM   #5 (permalink)
I didn't on mine, I think those yellow wires should never be touched, but for saftey I guess it is a good idea.
Old 03-14-04, 02:56 AM   #6 (permalink)
I took this apart twice. the first time i disabled the airbags like the manual says to do. the second time i didnt...and had no problems. just be careful with those yellow wires and that area down there and yo should be fine.
Old 08-24-04, 07:24 AM   #7 (permalink)
Blower Unit Replacement
Thanks for your detail procedures on removal. I have a problem maybe you can assist. Last week 16 Aug 04 my Legend AC blower was blowing very weak but the car was getting cold after driving for 15 min. Later in the week the blower completely stopped. I installed a new blower today it works great, but it is blowing hot air. I checked the condensor it is operating as before, I checked the AC tubing under the hood it is getting wet and cold, the controls are operating properly...what is it that I'm overlooking? Please advise.
r/gco
grovero is offline   Reply With Quote
Old 08-24-04, 08:44 AM   #8 (permalink)
Type I King
Car 1: 92 LS Sedan
i forget cause this was a while back, but u have messed up some wiring, you probably mixed up a plug, cause there is a plug for that. go back and chekc all ur wiring
Old 08-24-04, 09:41 AM   #9 (permalink)
has left the building
iTrader Score: 14 reviews
Bet he got the plug for the trunk release and the climate control module reversed. If he did, the control module gets fried and all it spits out is hot air. Made that mistake once as the 2 plugs are similar and fairly close to each other. To keep that from happening, mark the plugs with different colored markers.
stevieray is offline   Reply With Quote
Old 11-17-04, 10:07 AM   #10 (permalink)
Car 1: 1992 Acura Legend L-auto
Thumbs up Blower Removal
Thanks for you great DIY instructions. Here is my experience with this for all those who have a weak blower.
Symptoms: fan workes intermittantly and very slowly when it did, could get it to move by banging near the glove compartment area (like the Fonze)
Removal: much easier than changing the cv joints on my car, less messy and the actual blower is plastic so its not to heavy when installing/removing. 10mm socket, 8mm socket and phillips screw driver is all you need.
What I found: Yes, twigs, leaves and feathers in the cabin filter... I wish they installed a filter upstream to the blower so all that stuff would not get into such a hard to get place.
I opened up the blower and removed the motor. Motor was jam packed with carbon residue, since there are no open breathing holes for the motor. I cleaned all that out. I also noticed that after 150k miles and 12 year that there was only about 5mm left of the motor brushes, i could start seeing the spring on one brush ( brushes did not look like anything special, you should be able to find them somewhere). I put some grease on shaft and put it back together.
Result: Blower works just like it did 5 years ago just fine
Lessons: before buying a whole new blower, consider just taking a look at the motor and cleaning out the carbon and checking the brushes.
sc-fi_wasabi is offline   Reply With Quote
Old 01-23-05, 06:01 AM   #11 (permalink)
Car 1: 1993 Dark Green Legend 5sp
DIY Heater Blower Motor Brush Repair
I had an intermittent squeaky heater motor for about two years and it
completely stopped working a few months ago. I took it apart today and
applied 12 volts directly to the motor and it still didn't run. Since it's pretty
costly to replace (about $250 online, $300 part only at a dealer) I went a
little further and took the fans off the blower motor (used a small gear puller
and just pulled hard by hand) and took the motor apart (Philips screwdriver).
It was really dirty and one of the motor brushes was gone, completely worn
away. The squeaking was probably the spring scraping the copper
commutator. As soon as I can solder in a couple new brushes, I think it will
be fixed.
An overview on replacing brushes in an electric motor:
http://www.atving.com/atvconnection/...ech-Tip-28.cfm
Update: I soldered in two replacement brushes and put 12 volts to
the motor and it works! The motor costs $300+ at a dealer without labor.
The two replacement brushes cost me $3.50 for the set!
You'll have to find an auto electric repair shop or other electric motor
repair shop to find replacement brushes. Take this DIY job one level further
and save yourself a lot of cash!
Peter Chu
San Francisco
pcnotpc att earthlink dot net
1993 Dark Green Legend 5 speed, 165k miles
17" Koenig Imagine
pchu is offline   Reply With Quote
Old 11-19-05, 08:00 PM   #12 (permalink)
1 step before this one, I need to remove a plastic cover (1 on each side) to reveal that frame. Other than 2 screws, the cover seems to hang on with the clip or something that keep me from removing it. Wiggled it lightly didn't work. I don't want to break the cover or the clip. Anyone can elaborate this step please. Thanks a lot.
ndhduong is offline   Reply With Quote
Old 12-12-05, 06:10 PM   #13 (permalink)
aclegend
oMaiR's Avatar
Car 1: 2000 3.5 RL
Car 2: 95 Legend LS
blower motor removal
man the blower motor wont come out... have removed all the bolts but it wont fully remove cuz there is a metal bar in the way....
anybody kno a way around tat....
thanks in advance...
oMaiR is offline   Reply With Quote
Old 12-12-05, 08:48 PM   #14 (permalink)
3.52 ..Chicken & Dumplins
Boxing Champion, Square Bear Reversi Champion
whyteLegend's Avatar
iTrader Score: 17 reviews
Thumbs up
just want to THANKS Vancouver_Legend and other for your detailed info you saved my friend and I a total off $750 ON LABOR because I followed the info provided on this thread
THANK YOU
Click for Deep Discounts
http://4450488.shopwize.com
FS/Trade: JDM KA7 Headlights & Door Switch, heated seat switch
91-95 Sedan fender,3.5 RL HEADS , INTAKE MANIFOLD & FUEL RAILS ,
https://www.acura-legend.com/vbulleti...htside-124468/
https://www.acura-legend.com/vbulleti...ad.php?t=95844
whyteLegend is offline   Reply With Quote
Old 08-19-06, 12:27 AM   #15 (permalink)
TEXAS PSYCO
stella's Avatar
Car 1: 1991 LS coupe VGM(sold)
Car 2: 1994 LS coupe DMM
iTrader Score: 3 reviews
Send a message via AIM to stella
My A/C stopped working so I took it to the dealer to have it checked out. They wanted $700+ parts and labor!!! Bad blower motor. I found the blower brand new on ebay for under a hundred, followed the great DIY, and finished the job in less than three hours considering i had to splice some wires! I saved myself $600+ and i instaled a filter wich i did not have. I love this fourm!!!!!!!!!! Thanks to everone involved in this DIY! This is what "acura-legend.com" is all about!!!!!!!!
94' Desert Mist Legend LS coupe 6 Speed
stella is offline   Reply With Quote
