Maintenance Schedule - The Acura Legend & Acura RL Forum
Auto Insurance
Wheel & Tire Center
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 08-17-02, 08:37 PM   #1 (permalink)
502MotorSports.com
502 MotorSports's Avatar
Car 1: e39 540i | e28 533i [Euro]
Car 2: e60 530i | e46 330i
Car 3: S430
Send a message via AIM to 502 MotorSports Send a message via Yahoo to 502 MotorSports
Post Maintenance Schedule
Every 250 miles or weekly
Check engine oil
Check engine coolant level
Check windshield washer fluid
Check brake fluid level
Check tires and tire pressures
Every 3,000 miles or 3 months
Above listed items plus:
Check power steering fluid level
Check automatic and transmission/transaxle fluid level
Change engine oil and filter
Every 7,500 miles or 6 months
All items listed above and:
Inspect/replace wiper blades
Check/Service Battery
Check/Adjust (if necessary) engine drivebelts
Inspect/Replace (if necessary) all underhood hoses
Check cooling system
Rotate Tires
Check front disc brake pads
Every 15,000 miles or 12 months
Inspect the brake system
Check clutch pedal height and freeplay
Inspect the seatbelts
Replace the a/c air filter
Adjust valve clearances
Replace the air filter
Inspect the fuel system
Check m/t lubricant
Check differential lubricant level
Inspect suspension and steering components and driveaxle boots
Inspect exhaust system
Every 30,000 miles or 24 months
All above listed items plus:
Replace the spark plugs (conventional, non-platinum)
Check and replace, if necessary, the PCV Valve
Replace the fuel filter
Service the cooling system (drain, flush, fill)
Replace the brake fluid
Change automatic transmission/transaxle fluid
Change manual transmission/transaxle lubricant
Change differential lubricant
Check EGR system ( Exhaust Gas Recirculation)
Check and adjust engine idle speed
Check and adjust engine ignition timing
Replace ABS high pressure hose
Reset Maintenance Required Indicator
Every 60,000 miles or 24 months
All items listed above plus
Replace the spark plugs (PLATINUM TIPPED SPARK PLUGS)
Every 90,000 miles or 72 months
Replace timing belt
Replace water pump
Book mark for your reference, ladies and gentlemen.
502 MotorSports is offline   Reply With Quote
Old 08-18-02, 01:13 PM   #2 (permalink)
Guest
Posts: n/a
Thanks Leon, that's good to know, cause in about 10,000 miles I'll have to do a 30,000 miles service. Anyone know how hard this one is to do yourself, or is it just best to suck it up and go to the dealer?
Old 08-18-02, 07:53 PM   #3 (permalink)
502MotorSports.com
Car 3: S430
Most of them are DIY'ers.
I would think you could handle them all, at least with a little help.
Old 11-07-02, 02:51 PM   #4 (permalink)
Thanks...this was very helpful!!!!!
Mikeb120 is offline   Reply With Quote
Old 11-29-02, 03:24 PM   #5 (permalink)
Leon, your da man. I just lost my service schedule pamphlet that I got when I bought my car. This thread was a godsend.
g-man is offline   Reply With Quote
Old 12-25-02, 01:00 AM   #6 (permalink)
Should I do a 90k service for 120k? and if so are there any extras I should add on?
thanks
jewelerz is offline   Reply With Quote
Old 01-02-03, 08:40 PM   #7 (permalink)
I believe the 120K service is the same as 60K....you wouldn't do the 90K @ 120 since that includes the timing belt (which should have been done only 30K miles ago).
I just hit 120K, changed the oil and trans fluid yesterday, still need to do some more inspections and change the plugs and fuel filter.
Regards,
Sean L is offline   Reply With Quote
Old 04-03-03, 01:15 AM   #8 (permalink)
Type I King
Car 1: 92 LS Sedan
Car 2: 91 LS Coupe 5 spd
Car 3: 95 LS 6 spd coupe
iTrader Score: 7 reviews
Send a message via AIM to Hotstartup Send a message via MSN to Hotstartup Send a message via Yahoo to Hotstartup
how hard is to replace the brake fluid and the ABS fluid. the dealership is charging 70 bucks for both. should i go with them or do it myself??
Hotstartup is offline   Reply With Quote
Old 04-09-04, 04:04 PM   #9 (permalink)
a legend meet on how to do all this stuff would be really sweet.
cuz all i have done to my car for the last 6 months is change the oil.... and i dont know what the previous owner has done.
Ballistic is offline   Reply With Quote
Old 05-05-04, 04:45 PM   #10 (permalink)
Car 1: 1995 Acura Legend GS
iTrader Score: 4 reviews
Send a message via AIM to Roger
i got some questions i know how to do everything but :: Adjust valve clearances, Check and adjust engine ignition timing,Replace ABS high pressure hose.
-im thinking about doing an engine flush what do you think about that?
1995 Legend GS (sherwood Green)
174,000
My ride
http://www.cardomain.com/memberpage/608014
Roger is offline   Reply With Quote
Old 10-21-04, 09:42 AM   #11 (permalink)
FutureX 2001's Avatar
Car 1: '95 Coupe
Car 2: '94 Sedan GS
Car 3: '90 Coupe
iTrader Score: 3 reviews
Send a message via ICQ to FutureX 2001 Send a message via AIM to FutureX 2001 Send a message via MSN to FutureX 2001
Same question about Adjusting the Valve Clearances?
Hadn't heard of this before, should look in my manual and look at the list.. hehe
FutureX 2001 is offline   Reply With Quote
Old 10-21-04, 11:39 AM   #12 (permalink)
Can someone make a DIY on how to clean the PCV valve or at least take some pics of it and how to take it out?
shift is offline   Reply With Quote
Old 12-20-04, 10:44 AM   #13 (permalink)
60,000 or 90,000 miles?
My owner's manual says to change the timing belt rvery 60,000 miles. Where does the 90,000 mile interval come from?
Thanks,
Jack
jackpbqwst.net is offline   Reply With Quote
Old 12-20-04, 12:04 PM   #14 (permalink)
Thanks,
Jack
every manual is different some 60,000 some 90,000 at lest you dont have the one that says 40,000 that would suck. It seems they built the legends all allittle different, some you have to change the pads very 2,225mi!!! , im in search for a legend that requires no oil change, but im not losing sleep over this search.
174,000
My ride
Old 05-10-06, 06:06 PM   #15 (permalink)
what legend requires no oil change?
djcf is offline   Reply With Quote
