We now know the type 2 throttle body is superior, and the injectors are all the same and that type 2 FPR is best. But is there a difference in type 1 or 2 or RL fuel rails? Is one better then the other?
how is it superior?and the injectors are all the same and that type 2 FPR is best. But is there a difference in type 1 or 2 or RL fuel rails? Is one better then the other?
For reference, my mechanic also figured that keeping the Type I fuel rails/FPR when I did my 3.5RL swap was also the only way to still let it pass smog. In this same logic, I 'assume' that one would have to keep the Type II fuel rails/FPR when doing the same swap if, in fact, the car was a Type II to begin with.Lets clarify this the Type I and Type II fuel rails are the same. The FPR's are different. One is not necessarily better than the other, they are mearly different in terms of the amount of fuel they flow which is based upon the cams and air/fuel ratio maps. so they should be used in unison TII cams and ECU A/F maps use a TII FPR; TI cams, ECU and A/F map use a TI FPR. now the RL is a different breed all together and seems to work best wih the TI setup unless you have done some other things in the cam department. as fo rthe RL fuel rails I find them far more pleasant to the eyes as far as flowing more fuel I doubt it probably about the same. and any of the above have said to be adequate for more Hp than many of us will ever see.
That's good to know.The air porting on the TII TB is better than that of the TI allowing more air into the intake manifold it has one more inlet port than the TI.
No go with the Legend ones, I'm just saying swapping in general as "preventative maintenance"...I didnt and guess what code my ECU is throwing? You got it BOTH front o2's are bad....Just tryna help fellow swappers out change thos o2's while you have the motor out!91LS 3.5 you mean changing them to legend ones or just getting new RL style ones? I went with legend ones hope I didn't get the wrong ones
Where else are there o2 sensors besides the manifolds?
