i just took my car into my school today and i was told that i need to get inner and outter tie rods & and boot on the front driver side, right front ball joint, and right front caliper
1) is it possible that i need the tie rod parts if my car is aligned straight? (wheels pointed straight ahead, car even tracks straight when i let go of the wheel) the boot i know needs to be replaced as well as the upper ball joint on the right front end
2) i was told i need a new caliper cus the caliper isnt getting/building pressure of brake fluid. u know when u bleed brakes u should get a good amount of fluid coming out but there is barely any coming out at all and this is with the fluid topped off!!! so in turn i was told that the brake on the right front (where the "defective" caliper is located) isnt receiving enough or any brake pressure. but how can this be when
a) the car still tracks straight when braking
b) the car sat for about a month so the rotors got that rust look on it and
after a day of driving the rust went away on all 4 rotors
what do u guys think about all this..
