61 - 80 of 90 Posts
You dont even have to take off that piece, just lift up the carpet.
i dont know then, I'll have to take another look. I took it to my local mechanic, he said he looked there and couldnt find it, he thinks it was moved or something. He just told me to take it to acura, if my check engine light remains on.
Mine was tucked under the metal where the ECU is, just dig for it down in that hole.
:confused:
OK, the only thing left for me to do is rip up all the front carpeting. I still cannot find these black/white wires. And like Jrucch asked, where is the ECU at?! I dont have a check engine light yet but I want to be prepared.
jumper wires for ECU codes, location of ECU
:confused:
I am having problems reading my code. Check Engine light blinks once every two seconds. Indication a code #1=Left Oxygen Sensor, but I also notice the ABS light throwing a serires of codes, is that normal or does it mean something. Now the code I am getting does not make sense why my car feels like it wants to shut off while driving.?.
Had already replaced Main Relay, Spark Plugs, Idle valve, fuel filter & air filter. Still shuts off while driving or parked. :wtf: :confused:
Sorry to Necro this thread. But can the ECU throw a code without the check engine light coming on?
Im having weird problems with my G1.
The check engine light pops up sometimes and I have no idea why.
So I checked my ECU last night and it blinked like mad. No readable codes,
just blinking an orange light really fast with no stop to it. Any idea what the
problem might be?
I had a problem with "9 Number 1 Cylinder Piston Position " before but they changed
the sensor and it should be fixed now. That time the ECU blinked the code just as
it should. Now its just going mad...
EDIT:
Well it seems the Yellow light in the ECU means my idle is not set right.
So that solves the problem for that part.
Does anyone have the codes for the abs? Am getting a code 14 and idk what that means. I reset the ECU and it stays off for about 2 days and then comes bac on. Help pleaseeee.
Not necessarily. It just says "Electronic idle control." Could be anything that has to do with that.
but am not getting that code from the check engine light. Its from the abs light......1 solid blink and the 4 short fast blinks from the abs.
doh. That was from the G1 side of things. My bad.
if someone could take a picture of where the connector is for checking the codes.......BUT take one from a slightly farther distance like 2 feet back so we can get a better idea of where it is located.....
I head a quick look at most post in this thread but can't find the exact position of the 2 wires i know its under the carpet in the passenger side but where? does some one have a picture where it's located,
And how quick can you access them i thought it might be a handy thing to check out while buying a Legend.
Where is the connector exactly on a 1995 legend? Is it in the same place as posted above? I have looked and looked and cannot find it. Driving me crazy. It cant be that hard to find. Where the H... is it? FOUND IT!! So I put the paper clip in and I get nothing. What am I doing wrong? How far does it go in? There are only 2 holes it can go into right? I am getting no reading but the CEL always comes on. So need some help guys. Dont know a thing about these cars as I said it is my wifes car, but I am learning. Thank you in advance.
email me at vr4god@msn.com
Dave
61 - 80 of 90 Posts
