to install a timing belt...
1: you bring crank to TDC
2: advance it 15 degrees or so, so no piston is at the top **this prevents valves bending in case a cam slips
3: rotate cams to TDC marks
4: HOLD CAMS STEADY
5: bring crank back to TDC
6: install belt
so.... if i don't have money for the expensive tool... and the FSM is telling me that a pulley holder on the driven pulley **the rightbank's cam pulley**
....does this mean the left bank's pulley will stay still at TDC?
if not... the FSM should say that...
....w/o pulling the VC's, i should be able to just hold that right bank Cam gear and i'm good?
but this worries me...
if i slip before the belts on, then what's gonna happen?
like i said, i'm gonna need 8 damn hands for this...
any suggestions or hints on this?
4: HOLD CAMS STEADY
6: install belt
