problems with G2 legend need some help
Guys, i've been a happy Legend owner for 10 years now. Recently i've had some problems with the car that is not major but just more of a nag.
i have an automatic G2 legend.... two problems, woudl appreciate some input thanks guys:
1. the temperature meter would go up and hit almost max sometimes but immediately drops down to mid level when it hits max and moves up and down irregularly...
2. sometimes on a cold start the engine starts off at about 15000rpm but it keeps going up not down and when i put a brake on when driving , the engine appears to be @ a higher rpm than it normally does, about 11000rpm on a stopped position. i could feel the brakes trying to hold it down as it usually spins at about 6000rpm when @ a full stop. also sometimes when i put the car back to P, or off of a cold start, the engine would rev up and down really fast like someone's stepping on the throttle and releasing it really fast but its at a parked or neutral position and foot off the pedal.
i recently put in a new radiator, changed transmission oil, and the driving belts are changed about 2 years ago.
any input would be appreciated, thanks.
