1 - 8 of 8 Posts
Jryde03
Discussion starter · #1 ·
My father just put a tape in his radio and it wont come out, so i just changed his stock deck out for a 92 ls coupe stock deck. He has a 93 L Sedan and now the problem is that it sounds really crappy and doesnt go loud at all , you can start hearing it past the halfway volume mark and its so low, i know the 92 ls coupe had the amp under the seat but im not sure about the sedan, im guessing the first deck had a built in amp and the coupe deck only has like 20 watts or something like that.... anyone ever had this problem and know how to fix this?
Thanks
-john
You can't replace a LS head unit (probably a Bose) with a L model HU. I would think the wiring harness is different and the Bose speakers are 2 ohm instead of 4 ohm.
This thread would probably be better placed in the Stereo section. Welcome---
Discussion starter · #3 ·
i know that's what i thought? because my brother(Frantinez) has a 92 ls with bose and i have a 92 l without bose but my father's 93 L sedan has bose , the rear tweeters and all, the wiring and plugs fit and everything its just it doesnt go loud at all?? any suggestions?
Also I know the 91-92 Bose system was only 80 watts, whereas the 1993 on up was 200 watts. If the sedan has a 200 watt amp, maybe the coupe radio is having a hard time regulating that. (This opinion is from a layman's perspective and is not meant to be technical.) :)
Discussion starter · #6 ·
Thanks for the advice guys, probably just going to have this 4 channel amp i have wired up for him.. Dont have time to try and diagnose a problem which probably is going to result in putting an amp in anyway.. thanks anyways
Discussion starter · #8 ·
Thanks man, i figured that but now i know for sure...cool.. So does anyone have a headunit from a 91-95 L that they would want to sell, it would be easier than me wiring up a 4 ch amp and spending all that time... Let me know
1 - 8 of 8 Posts
