is there such thing as a real electric supercharger? not those stupid ebay ones....
I am going to be doing this as I said before. There are ways to do it but it takes time. I have found some things that would be able to get it to work. Basically the only thing making it difficult now is the power to run it. All I need is some time though and I will have one going.cigarettcancerman said:ive seen these for sale on ebay and there are alot of bad comments.. the ones that are good i assume its because these electric turbos usually come with a high flow filter too, so if your going from stock then i think you would notice a little power and leave a good comment...
If i saw some actual test results from a decent source i would consider it but not a moment sooner. im sure a electric leaf blower motor would put off more pressure than those things, go buy a cheap one for like 40$ that has like 2.5hp
I read the whole article on the Knight electric supercharger, supposedly the problem has been: in order to get enough boost to make a real difference, you need a huge amount of current, in order to supply that current, you need the equivilent of several alternators, the greatly increased drag from the additional alternators cancels the power boost from the supercharger... no gain....88_acro said:most of things you describe can be fixed
-Plastic fan blades: get metal ones
-shrappnel in engineut the blower before the filter or chicken wire after the blower
-low and high speed no good: have a switch to turn it on when you want
i believe the electric supercharger COULD work but no one wants to take the time/money to do it when you could just get NOS. plus it would look like a ricer thing or like sh it
You got the right idea, but I think your numbers are way off. A hair dryer is like 1600 -1800 watts. It has a heating element that uses most of that, but even if you assume the motor only uses 300 of the 1600-1800, you are still left with a tiny wimpy assed motor that could never put out 8psi.. Also remember you need both pressure and velocity, my little 'plug into the cigarette lighter' air compressor will put out 120 psi but it will only move something like .005 cfm so even at idle it won't make any pressure. If you get a blower motor that will put out good air pressure, it has to be able to build that pressure at the flow rate of our cars at w.o.t. at redline in order to be truely effective. I think to get 8 psi at the appropriate flow rate you're going to be looking at something in the range of 4500 watts, try that calculation for current at 12V!!! How many 100 amp alternators would it take just to run that blower? Where's the gain?LegendaryASH said:On the current 12V DC car power system having an electric supercharger is pointless becuase of amperage required to move that much air.
If they ever decide to move into 24V or 42V DC systems for cars (they have been working on it as of now but when you up DC Volts the risk of arcing greatly increases so they have been working on the safety systems to go along with those increased volts) things such as these will be much easier to produce. Simple physics tells us W=A*V where W=watts A=amps and V=Volts
Say to push 8psi of air we need a 300W electric motor on a 12V car we would need 25 amps to push that air, whereas a 24V car would only need 13 amps and a 42V car would need only 7 amps of power.
One type of performance system I have been thinking of is take a turbocharged car and add an electric motor that upon a full throttle input from the driver prespools the turbo to get rid of most if not all of the turbo lag. You could kind of think about it how honda's IMA system works, a little motor ot help the bigger one out. in this case a simple 1/4-1/2 hp high speed rotation electric motor that helps the turbo get upt to speed.
It can be done. Have you been following how brushless motors are changing the way things have been done? They draw less current and provide more power than ever thought possible. 8 Psi is no where near where you would want to go with an electric supercharger. It would require too much current but in time it will be possible. More like 3-5 Psi is doable now and hopefully I will get things going here soon. Like I said I am working on it and you all will see how easy it is and how cheap it will be to make. It will take up very little space and use 12-24 volts to run. Brushless motors are going to make it possible and it will work better than Knights idea.maytagman said:cigarettecancerman: turbo engines do need regulation... this is what a wastegate is. all turbo engines SHOULD have a wastegate and if you dont you will mostlikely blow up your engine. what a wastegate is is a bleed valve on the exhuast manifold that opens via spring under a specified amount of boost. a legend turbo might run say 8psi boost... the spring in the wastegate would be an 8psi spring. 8.1 psi would open the spring and vent pressure maintaining a max 8psi.
what a turbo actually is: a vacuum powered vacuum reducer. vacuum = negative pressure = slow. boost = positive pressure = fast.
what a supercharger is: a belt driven vacuum reducer.
superchargers and turbochargers slow your engine down at low speeds. this is called turbo lag. they add a whole bunch of added restriction on either your exhaust or your belt system. but the good thing is that once your engine gets up to speed momentum kicks in and so does the power!
an na(naturally aspirated)2.7l legend would be faster than a turbo2.7l legend off the line, but after the 2.7l turbo spools up it would smoke the na2.7.
why electric superchargers dont make sense: YOU KNOW HOW MANY AMPS IT WOULD TAKE TO PUSH 8PSI BOOST INTO AN ENGINE?
better install a second alternator! cuz where else is all of this added electricity demand coming from?
then you are back at square one... a belt driven supercharger. just in two parts...
this really doesnt make sense guys...
i could see using one for a drag race... but that is pretty homersexual if you ask me...
a lot of work for squat in gains...
you are better off buying one of those tornado intake devices
and btw thats a joke... dont ever buy one of those pos.
maytag
You missed the point. I was just saying it can be done and the newer motors create more power with less power input. Less amps but more power. I will be working with a system that will hopefully make 3-5 PSI. The motor will be able to make the power for longer than just a few seconds and when it does get too hot it will shut down and the system will be bypassed. It will work and when it does I will sell you onemaytagman said:how long does a starter draw 250-500 amps for?
i just think its not very practical
8 psi would blow up a legend motor in no time
but things dont get fun till about 12 psi
you plan on using a wastegate?
maytag
logic said:You got the right idea, but I think your numbers are way off. A hair dryer is like 1600 -1800 watts. It has a heating element that uses most of that, but even if you assume the motor only uses 300 of the 1600-1800, you are still left with a tiny wimpy assed motor that could never put out 8psi.. Also remember you need both pressure and velocity, my little 'plug into the cigarette lighter' air compressor will put out 120 psi but it will only move something like .005 cfm so even at idle it won't make any pressure. If you get a blower motor that will put out good air pressure, it has to be able to build that pressure at the flow rate of our cars at w.o.t. at redline in order to be truely effective. I think to get 8 psi at the appropriate flow rate you're going to be looking at something in the range of 4500 watts, try that calculation for current at 12V!!! How many 100 amp alternators would it take just to run that blower? Where's the gain?
As far as the electric motor to spool the turbo, you're looking at the same trouble, the turbo's got a lot of mass and it builds wind resistance pretty quick. in order for your little motor to help, it has to not only be able to spin quickly, but it has to have a lot of power to accelerate the mass of the turbo quickly. There's a lot of small motors that will be able to spin fast, but they don't have enough torqe to spin the turbo up even as fast as the car's exhaust... To eliminate turbo lag, I'd think about nitrous that only activates under the condition of full throttle and no boost. It would give you power boost to get you to the point of turbo coming on line and then shut down as the turbo kicks in...I was even thinking of having several really small jets injecting the nitrous so the computer that controls the nitrous could cut an injector at each level of boost so you wouldn't even feel the transition between nitrous and turbo...[/QUOThe numbers I was posting were just for demonstration. I know for a fact that 300W could never move 8psi of air, I was just demonstrating simple physics. As for the electric boosted turbo, the motor would not have to move the whole mass of the turbocharger. The airflow in the exhaust would do most of the work. Take this principle like the honda IMA system in the insight. A 15hp electric motor to supliment a 67 hp gas one. Well in this case all we are trying to do is speed up the rate at which the turbo spools. It wouldnt take that much power to do really because the turbo can do it fine on its own just an assist would help it do so faster. Also if initial current draw was high the system could always have a capacitor system to help that inital draw since when typical electric motors are at low speed high torque they use huge amounts of wattage compared to when they are at high speed low torque situations.
the electric motor on the turbo could theareticaly work. but u would run into issues of over heating motors because the turbo gets HOT and i bet someone either has a paten on this or has triedLegendaryASH said:The numbers I was posting were just for demonstration. I know for a fact that 300W could never move 8psi of air, I was just demonstrating simple physics. As for the electric boosted turbo, the motor would not have to move the whole mass of the turbocharger. The airflow in the exhaust would do most of the work. Take this principle like the honda IMA system in the insight. A 15hp electric motor to supliment a 67 hp gas one. Well in this case all we are trying to do is speed up the rate at which the turbo spools. It wouldnt take that much power to do really because the turbo can do it fine on its own just an assist would help it do so faster. Also if initial current draw was high the system could always have a capacitor system to help that inital draw since when typical electric motors are at low speed high torque they use huge amounts of wattage compared to when they are at high speed low torque situations.
maytagman said:i love my acura legend... dont take this the wrong way... but if you want lots of turbo power on a tight budget? pick up an 1988 audi 90 quattro for $2000 or less... buy an audi 5000 10v turbo motor for $500 then maybe $1000 worth of extras... its an easy conversion and there are tons of specialized parts etc.
as soon as im rich... or better off im going to do a second conversion...
my first was a success but died eventually...
very satisfying project...
not to diss my legend...
but turbo awd in a car slightly nicer than the legend...
but the legend handles nicer... after all its a tiny coupe
dont get my wrong... ill probably own a legend forever
maytag
ps my audi friends are disgusted by me owning a jap car...
but i respond "lets race"![]()
